It is currently Sun May 05, 2024 9:26 am
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 4 posts ]
PostPosted: Thu Jan 12, 2006 3:31 pm
There have been quite a few people posting questions about cone compressors, and whether or not cones can be installed with or without one etc.
After a bit of research, I did it myself, and I decided to document it here for the noobies (including me).
One empty suspension tower
One rubber cone
Lubricate the thread in the cone - just as drmini always says
Put the cone into position
Make sure that it sits in its proper place
This is what "MY" cone compressor looks like! A 3/4 spanner, a big washer, two subframe spacer plates, and a high tensile 1/2inch x 4inch bolt.
Let's put it together:
Step One
Step Two
Step Three
Step Four
Step Five
I turned it by hand first, to make sure that it started in the thread properly, then used the spanner to turn it about 10 times. This gave me enough clearance to put in the strut and top arm.
Get your strut and top arm ready
Grease them up and assemble them
This is how I put on the rubber seal on the front most end of the arm. It helps when installing the arm, and can be put into the correct position later.
Ease the arm into the suspension tower, start by making sure that the strut finds its proper place in the rubber cone
When the strut is positioned, then get the arm to line up properly (so that the pivot pin can be inserted).
Assemble the pivot pin, retaining plate, spring washer, nut
Don't forget the thrust bearing! It should be the THICKER of the two thrust washers.
Insert the pivot pin
Bolt in the retaining plate
Put the spring washer and nut on the other end of the pivot pin (I haven't got the spring washer on in this pic).
When all the nuts and bolts are done up properly, it's time to let the cone go.
It's time for the 3/4 inch spanner to come out again.
And this time, he might need a friend to help...
And there you have it!!!
Cone, strut and toparm installed without a $100 compressor, and without much swearing or sweating! I will have to use my "compressor" again when I fit some new rebound rubbers, I'm sure that it will be up to the task for another round of cone compressing!
PostPosted: Thu Jan 12, 2006 3:52 pm
We did something similar but with rod and cut a thread in it we also cut the coarser thread at the other end of the rod so that now my tool does both threads :D
ours was a bit different we used two nuts to lock up we we could srew the rod into the cone and then once screwed into the cone then screw the bottom nut down against a bit of plate (forgot to mention this bit) to compress the cone :wink:
Roads need more corners
 Post subject: mini
PostPosted: Fri Jan 13, 2006 9:16 am
Nice quality tools.
:wink:
*Reasonable pricing
*I come to you..
Jay: 0431404607
PostPosted: Fri Jan 13, 2006 9:42 am
Thanks and nice tutorial :)..
I will save that in my hints and tips folder :).
Opinions expressed by me are of my opinion only and are copyrighted to Kinkabell Corporation? 2006.
