What Outer CV joints are people using? https://ausmini.com/forums/viewtopic.php?f=23&t=91345 |
Author: | Dutchy1978 [ Tue Dec 22, 2015 8:55 pm ] |
Post subject: | What Outer CV joints are people using? |
I am getting closer to organising the driveshafts for my Vtec conversion but think it might be best to change the outer cv's to something stronger. I want to do work to the motor in the years to come so I might as well get strong driveshafts and cv's now (do it properly first time.) I currently have Rover mini cv's and hubs. I see Allspeed engineering do the HD cv's from a Vauxhall and matching shafts but as my subframe is home made the lengths may be different. Anyway, the question I am trying to get to is.....what are people in OZ doing about their outer cv's? are people converting them to something stronger or not? If so the what too? Does another cv fit directly into the mini hub? |
Author: | Harley [ Tue Dec 22, 2015 10:01 pm ] |
Post subject: | Re: What Outer CV joints are people using? |
I think there's only one other CV thats a direct fit to a mini hub and thats ones from an Austin Maxi: http://www.ebay.com.au/itm/Austin-Maxi- ... 0783032993 They're visually bigger in the CV joint end than mini ones, but I'm not sure if the inner cage is still the same or also bigger. |
Author: | patwilliamson [ Sat Jan 16, 2016 8:02 pm ] |
I use allegro 1500 outers on race car. Yes they accept disc brake hub. Just fit within the hub structure and bigger cage assembly. I used maxi drive shafts cold welded to honda inners. They did crack however and now I use billet shafts. I would expect welded shafts will suffice on road car. Less grip level from road tyre. |
Author: | Bennjamin [ Wed Jan 20, 2016 6:39 am ] |
Why not consider the ALLSPEED HD outer joint with HD shafts ? These will work fine with your setup - but require some standard Honda shafts (or bits) to scavenge the boots and the tripod bearings with cup. |
Author: | Dutchy1978 [ Wed Jan 20, 2016 11:12 pm ] |
Bennjamin wrote: Why not consider the ALLSPEED HD outer joint with HD shafts ? These will work fine with your setup - but require some standard Honda shafts (or bits) to scavenge the boots and the tripod bearings with cup. I have thought hard about these but there are two things stopping me at the moment. 1. The exchange rate is killing us right now 2. I would like the axle shafts too but my lengths may be different to theirs. Once I get the car back on its feet I will re assess. Good driveshafts are important so I don't mind spending the money to do it once. Especially knowing that I will probably modify the engine down the track to gain more power. One of the reasons why I asked the question is that I can get new driveshafts made for about $600 a pair so all I need to know is what strong outer CV's suit the mini hub or can be slightly modified to fit. |
Author: | Bennjamin [ Thu Jan 21, 2016 5:40 am ] |
You could go the HD joints and then custom up the shafts ontop ? They are Vauxhall in era with a mini disc brake outer- wouldn't be hard to make something up to suit |
Author: | Dutchy1978 [ Wed Jan 27, 2016 5:03 pm ] |
Bennjamin wrote: You could go the HD joints and then custom up the shafts ontop ? They are Vauxhall in era with a mini disc brake outer- wouldn't be hard to make something up to suit Don't you mean Honda inner and Vauxhall outer? Any ideas what Vauxhall it hey are from? Or Holden in Aus. |
Author: | Harley [ Wed Jan 27, 2016 5:23 pm ] |
Unknown to me exactly but I was under the impression they're from 2.0 Astras or similar. But you wouldn't buy one from Holden here and mod the end to suit the drive flange - that would cost a fortune! |
Author: | Bennjamin [ Wed Jan 27, 2016 6:33 pm ] |
Dutchy1978 wrote: Don't you mean Honda inner and Vauxhall outer? Any ideas what Vauxhall it hey are from? Or Holden in Aus. I mean Mini outer (fits into the disc hub) and vauxhaull splines. The honda part is the end which sits in the cup/cage. No idea of what its from - refer to this http://www.allspeedengineering.com/inde ... int-detail |
Author: | Dutchy1978 [ Wed Jan 27, 2016 8:38 pm ] |
Harley wrote: Unknown to me exactly but I was under the impression they're from 2.0 Astras or similar. But you wouldn't buy one from Holden here and mod the end to suit the drive flange - that would cost a fortune! True Harley. Don't you have the HD ones from Allspeed? Bennjamin wrote: Dutchy1978 wrote: Don't you mean Honda inner and Vauxhall outer? Any ideas what Vauxhall it hey are from? Or Holden in Aus. I mean Mini outer (fits into the disc hub) and vauxhaull splines. The honda part is the end which sits in the cup/cage. No idea of what its from - refer to this http://www.allspeedengineering.com/inde ... int-detail Yep that's the one I thought you meant. It's looks to be a Vauxhall CV that has been lathed to fit the mini hub. It can't be a mini CV with a Vauxhall ball bearing gear as the drive shafts are shorter for the HD version, 267mm vs 287mm for the Honda to mini shafts. If I know what the HD cv's are from then I can get the shafts made locally for about $600 for complete new ones. |
Author: | Dutchy1978 [ Wed Jan 27, 2016 9:28 pm ] |
Yeh good call. I might just do that. To buy the complete set up from Allspeed will be ridiculous now the exchange rate is crap. You purchased at the right time. |
Author: | Harley [ Wed Jan 27, 2016 9:32 pm ] |
The more you can buy off the shelf the better I figure. If I break one I'll have a newy from allspeed in a week! |
Author: | Dutchy1978 [ Wed Jan 27, 2016 10:07 pm ] |
Yeh your probably right. I have enough custom stuff already which will be annoying when any of it needs replacing. Hopefully a long time away. I'd hope I didn't break a HD driveshaft though. The car won't be that powerful. |
Author: | Bennjamin [ Thu Jan 28, 2016 6:17 am ] |
Harley wrote: The more you can buy off the shelf the better I figure. If I break one I'll have a newy from allspeed in a week! What he said. We both have a good point - it's expensive from ALLSPEED but it works. And it's only a week away from a pair ! |
