It is currently Fri Mar 29, 2024 4:09 am
PostPosted: Fri Dec 06, 2013 6:37 pm
Yes, you did read it right. Ausmini keyrings and stickers are back in house.
Batch 2 Keyrings are now improved again over the Batch 1 keyrings in that they still have the pressed and enameled Ausmini Logo, but are also now coated in a glossy clear resin. There is now also no order limit.
Stickers are 600 mm laser cut vinyl available in white, black, red, light blue, and dark blue. The image does not show the true colours because of the protective colour, but they are are vibrant!
Keyrings are 12 dollars each including post.
Stickers are 5 dollars each, including post.
Profits from the sales will keep the Ausmini wheels turning, with thanks from the Ausmini users, moderators and admin. :wink:
Ordering is via the Ausmini Donate button HERE, or at the top right of the screen between FAQ and SEARCH
For payment you will be transferred across to PAYPAL. It is here that you will need to insert your address details in the Note to Seller prior to payment being completed.
Please do me a favor here, and write your address exactly as you would write your address on an envelope. This will help me to make sure the keyrings go out correctly. Also tell me exactly what it is you have ordered as this could be a combination of keyrings and stickers, including the colour!
PostPosted: Mon Jun 30, 2014 12:58 pm
Hi Mick, I would like to order 4 Key Rings please. I tried to go to the Donate bit but itv is telling me that it is in a different format to my PayPal system. How can I do it? I want 4 Key Rings Posted to
Tony Buttigieg
517 Camp Cable Road
Jomboomba
QLD 4280
"Let us remove your "SHORTS"
PostPosted: Mon Jun 30, 2014 5:41 pm
Jimboomba :) don't want any mix-ups.
Why Drink And Drive When You Can Smoke Dope And Fly!?
PostPosted: Mon Jun 30, 2014 5:47 pm
I've tested you permissions, and it looks normal to me, although it may not look normal to you.
You scroll to the bottom of the page, select the number by price and press the donate. It will take you to the normal Paypal screen after that.
I'll drop you a PM.
Mick
PostPosted: Tue Jul 08, 2014 5:03 am
I got the order. Thanks Mick.
PostPosted: Tue Jul 15, 2014 12:46 pm
No trouble.
PostPosted: Tue Feb 10, 2015 10:26 pm
Frank Ollie, If you're reading this could you please send me your mailing address for the order (and thanks by the way). The email address bounces unfortunately..
PostPosted: Sat Feb 03, 2018 9:25 pm
Don't suppose there's any still up for grabs, is there?
Sent from my SM-G925I using Tapatalk
