Boot liner https://ausmini.com/forums/viewtopic.php?f=2&t=97746 |
Author: | Midge [ Tue Sep 11, 2018 7:50 am ] |
Post subject: | Boot liner |
Hi, can anyone tell me if there was a boot liner made for a 1976 Mini if so where I may be able to get one. Thank you |
Author: | timmy201 [ Tue Sep 11, 2018 10:44 am ] |
Post subject: | Re: Boot liner |
If you have the bigger tank (7.5 gallons) then there is a pre made one available. It says it will also fit earlier cars with the smaller tank (I assume there will be a small gap on that side) https://minikingdomonline.com.au/product/boot-liner/ Also flat ones: http://minisport.com.au/mini-boot-board ... 5gal-tanks http://minisport.com.au/mini-boot-board ... tank-minis If you want a lining kit for the boot lid: http://minisport.com.au/boot-lid-liner- ... o-cooper-s You can also buy some plywood or similar from a hardware shop and cut them to size |
Author: | Bubbacluby [ Tue Sep 11, 2018 11:05 pm ] |
Not sure when first arrived. but originally later model leyland minis were fitted with a boot mat that clipped to the boot lid and then lined your boot floor covering spare and battery. |
Author: | turbosuzi [ Fri Oct 12, 2018 7:07 pm ] |
I managed to source one of these second hand for my 74. Not sure what models had them and what didn't tho.... |
