phillb wrote:
jprior2912 wrote:
Thanks for your replies everyone
I just went out and inspected my carbs. Is this the correct screw I need to turn?
Important. In your photo there is also a screw just to the left of idle screw that points toward a cam. (no 3 in the diagram) Double check that your choke is right in and that while you adjust the idle there is a gap between the end of that screw and the cam that it points too.
Then after you have adjusted your idle make sure there is still a small gap there. Probably won't be an issue for you in this case because you are increasing the idle and so that gap will increase, but basically when everything is set and the choke is right in there should always be a small gap there.
When you begin to pull out your choke that cam rotates, pushes the screw and therefore increases the idle with choke. Watch while someone pulls the choke out and you will understand how it works. Also check that when the choke is pulled slowly out that you can see both carbs throttles open approx same time/amount
The method with the tube Mick suggests is the way my Dad taught me and I've also found it the best method for balancing.
Thank you Phill, I made sure there was the gap so should be all sweet now.
Mick wrote:
Twins!
Once you have sorted out the idle adjust screws on both, then you need a meter or so of 1/2" heater hose.
You put the heater hose to your ear, and then the other end in the mouth of the carb at about the same position for each. If one sounds higher than the other, then it needs to be closed a little, or the other needs to be opened a little.
Very small changes in each carb adjustment make big changes in sound, so it is very effective. I prefer this over the expensive carb air flow meters
Thanks Mick
What is meant by the 'mouth' of the carb exactly? Doesn't seem to be anywhere I can stick a hose in haha
