Mini cylinder head question https://ausmini.com/forums/viewtopic.php?f=2&t=102269 |
Author: | winston5454 [ Sat Apr 13, 2024 7:13 pm ] |
Post subject: | Mini cylinder head question |
Hi , I dragged an old 12g 202 cylinder head out of the garage and started dismantling it . I am fairly certain it has not been modified in any way . Question is when looking down the 2 inlet ports there is virtually no divider to guide gases into the separate cylinders . Does this sound right or maybe at some stage there has been a grinder in there ? Regards , Winston . |
Author: | Steam [ Sat Apr 13, 2024 9:03 pm ] |
Post subject: | Re: Mini cylinder head question |
Only 1 cylinder is drawing at a time so all the mixture will go where it is needed. |
Author: | Bill B [ Sun Apr 14, 2024 3:48 pm ] |
Attachment: 202 head inlet ports.jpg For the sake of comparison to your cylinder head, this is a 202 head I have, looking down the inlet port to the divider. It was ported by Lynx engineering in the '70s.It is a bit hard to get the right lighting for a clear image (I've got better colonoscopy photos). But I think you can see original casting marks on the divider, how far back in the throat it is and no signs of grinding/polishing either. |
Author: | GR [ Thu Apr 18, 2024 6:39 pm ] |
Hi Winston 5454 That is std for a 202. Hi Steam The mini has 2 inlet valves open at a time that is why the try to scatter the cam 1 and 4 different to 2and 3. Graham Russell |
Author: | Steam [ Thu Apr 18, 2024 6:53 pm ] |
GR wrote: Hi Winston 5454 That is std for a 202. Hi Steam The mini has 2 inlet valves open at a time that is why the try to scatter the cam 1 and 4 different to 2and 3. Graham Russell G'day Graham, But surely only 1 is drawing as I said? |
Author: | drmini in aust [ Thu Apr 18, 2024 7:23 pm ] |
Due to inlet cam duration there is a time when both are open. 2nd one robs charge from the first. |
