Clubman GT gauge cluster https://ausmini.com/forums/viewtopic.php?f=2&t=102264 |
Author: | GuamMini [ Thu Apr 11, 2024 4:34 pm ] |
Post subject: | Clubman GT gauge cluster |
How does the plastic part of the gauge cluster attach? mine is loose it does not want to stay in place is it mounted by screws? |
Author: | Steam [ Thu Apr 11, 2024 5:54 pm ] |
Post subject: | Re: Clubman GT gauge cluster |
If you mean the outer housing then it uses clips with teeth that grip in a slot in the housing. I can try to get a photo 8f you need it. |
Author: | GuamMini [ Fri Apr 12, 2024 9:40 am ] |
Steam wrote: If you mean the outer housing then it uses clips with teeth that grip in a slot in the housing. I can try to get a photo 8f you need it. That's what I mean, thanks, appreciate it |
