1275 head gasket https://ausmini.com/forums/viewtopic.php?f=2&t=102261 |
Author: | Goldbrocade_62 [ Tue Apr 09, 2024 4:02 pm ] |
Post subject: | 1275 head gasket |
1275 head gasket what are people using now a friend has had one fail after a couple of months and not many klms done unfortunately I don't know which one the used |
Author: | drmini in aust [ Tue Apr 09, 2024 6:21 pm ] |
Post subject: | Re: 1275 head gasket |
Payen AF470 Retighten when hot and again after 1000km or so. |
Author: | Goldbrocade_62 [ Tue Apr 09, 2024 6:53 pm ] |
drmini in aust wrote: Payen AF470 Retighten when hot and again after 1000km or so. Thank you will pass the information on |
Author: | Steam [ Tue Apr 09, 2024 7:16 pm ] |
I would suggest finding out why it failed once apart. He may have further issues. |
Author: | Goldbrocade_62 [ Wed Apr 10, 2024 12:04 pm ] |
Steam wrote: I would suggest finding out why it failed once apart. He may have further issues. I'm nots sure what happened was put in a mechani head was redone by a reputable person reco carb block deck checked |
Author: | Steam [ Wed Apr 10, 2024 1:54 pm ] |
If the timing is out it can cause head gsket issues, and the new chinese distributors are prone to wild timing variations. |
Author: | 68+86auto [ Wed Apr 10, 2024 4:12 pm ] |
Goldbrocade_62 wrote: Steam wrote: I would suggest finding out why it failed once apart. He may have further issues. I'm nots sure what happened was put in a mechani head was redone by a reputable person reco carb block deck checked unfortunately reputable doesn't mean much. There's one here who can't check dwell at all or even do timing correctly but rebuilds mini engines for people. Since the block and head was supposedly checked then the gasket itself is unlikely to be at fault. |
